Wiring hoop.
I am on day 2 putting together my 96x48 PRS standard. I have the x car on and I am ready to start wiring tomorrow. I have been doing most of it myself and I am taking my time. I installed the clear plastic hoop that holds the wiring up it seems to be too long. I put it on and moved the YZ car full in the front position and it barely misses my ceiling by 8" when I slide it to the rear rail it is against the ceiling big time when I put a vac hose on it will really be a problem. I am wondering if they sent me one for a 60" wide table. Would it hurt anything to just cut it a little shorter and re-drill the mounting holes?
Mike
Michael
The hoop can be modified.Check out this link-
http://www.talkshopbot.com/forum/messages/28/22269.html
THis is what I did
Erminio
I solved the problem I cut 6" off each end and drilled new holes to mount it the way they designed it. Works just right I used the cut off ends for templets to drill the new holes.
Mike
