I'd like recommendations for bits, speeds and feeds, # of passes etc... for cutting intricate shapes in 5/8" thick maple. I also need the smoothest finish possible which may be a problem as I need 1/4" (or smaller) bits to achieve the tight radius cuts but i've learned that the best finishes come from 3/8"+ bits. Any thoughts on this would be greatly appreciated. Also I've read of people using one bit to "rough" cut it then stepping it in with a finish bit to polish the whole edge in one final pass. Anyone have experience with that? I'm cutting US state shapes mostly that are 3-4" big
I also plan on cutting a lot of 5/8" to 3/4" cherry and walnut. Some are intricate shapes and some not. I have a t slot table(no vac) and plan on using transfer tape with spray adhesive to hold pieces in place while cutting. A bit tedious I know but could I just use double sided tape to my sacrificial? Any thoughts on how to set up table?
I know of the bit maker onsrud and they are helpful in bit selection but don't have the real world experience you guys do. Which "series" of bits might you recommend. Would I even need to hold the piece in place with tape if I use a down spiral bit? I don't necessarily mind a little post production work on the edge sander if necessary and I will round over and sand the top and bottom edge anyways.
Hope there's no rule against going on too many tangents!? A lot of questions here but any and all opinions are welcome. Thank you in advance, Justin
