Results 1 to 10 of 13
Thread: Easy Hold Down Technique
    Norman, Ok
    Default Easy Hold Down Technique
    I've previously posted a technique used for holding small, or difficult objects. It can be used for any size however.
    The photos shows our favorite foam adhesive and the despencer. It's from Deman Products. The can has lasted me about a year. It costs about $15.00.
    Here's the way I do it.
    Use a scrap substrate like MDO, Melomine, Plex or just about anything, on which you can place your "To Be" routed material. Go around the side of your routing material with the foam. Not underneath. This sets up in about 10 minutes. Now just screw or clamp the larger substrate to the router bed.
    When finished routing, you can go around the sides with a putty knife and along the bottom to relieve it. Don't worry about this stuff giving up the Ghost. It's really tough.
    Joe
    Jul 2004
    Campton, KY
    Shucks, I wish I'd thought of that. I like it Joe, thanks.
    Jun 2007
    Adirondack Routing and Signs, Morrisonville NY
    Joe,
    I looked on the web and couldn't find the product? Did you find it at one of the local big box stores?
    Norman, Ok
    Robert,
    The product is EnerFoam 42 made by Demand Products. It's on page 39 in their catalogue or you can find it by a search for glue.
    This is a really tough, tough stuff that cleans up nicely when cured.
    www.demandproducts.com
    Norman, Ok
    Robert,
    Joe,
    Is that stuff only to be used adhereing foam to a substrate or can you use it to adhere things like mdf or wood?
    Wild Atlantic Way
    I have used the same principle, but with a hot melt glue gun.....it sets in seconds.
    Paul
    Norman, Ok
    Jack,
    I'm not sure. It seems this is much like Gorilla Glue only less dense. It's a good thought and might be worth a test or two.
    Holding smaller pieces for routing has been the subject of discussion for some time. And the most common solution offered, has been Vac Pucks or throtteling down a big vac area. What a pain. Since we scrapped our whole vac system, three years ago, it's been clear sailing with physical hold downs.
    I'll post a few other novice techniques as time goes along. The Oak object in my photo is one of my newly designed hold downs. I have three sizes. This one is 12".
    Jan 2007
    Pennsylvania & Florida
    Joe,
    I make signs too, and sometimes find using the vac to hold down a challenge due to the vast variety of material I work with. It seems we are constatntly changing the materials that are laid up on the bot. I am surprised that you are only using mechanical hold down now though.
    I am even an old EIFS applicator... but never thought of that. Thanks for the tip on the Demand spray foam !
    John
    Norman, Ok
    John,
    It's good to hear from another sign fellow.
    We are a little different from the regular sign shop in that our product line is only dimensional signs. Years ago we made banners, realty signs, lettered vehicles, etc.
    While a good vac system can be an asset on some flat stock it's not very good at holding down a rough cedar plank, or redwood panels or most anything we do. Not to mention deliclate small pieces. Good old physical attachment seldom loose their grip and are less expensive.
    If I had the best vac in the world, it would set idle.
    Perhaps a quick view of the website will describe better our product.
    www.normansignco.com
  1. 2 sided technique
    By ADAPT_Shop-Brady in forum Techniques for Cutting, Drilling, Machining
    Last Post: 09-15-2016, 07:01 PM
  2. Gold Lettering Technique
    By joe in forum Sign Making
    Last Post: 12-31-2015, 01:18 PM
  3. Easy work easy money.
    By genek in forum Folder 2015
    Last Post: 04-06-2015, 08:26 PM
  4. Shocking Technique
    By Mayo in forum Techniques for Cutting, Drilling, Machining
    Last Post: 01-28-2015, 01:58 PM
  5. Climb Cut Technique in ArtcamPro
    By jim_hoffman in forum Archives2006
    Last Post: 05-21-2006, 11:01 PM
